Got a good deal on some boost forks but will need to get adaptors for my hubs.
I have to option of the fancy mrp better boost kit for £40 With proper end caps or the cheapo eBay kits which just consist of the spacers and longer rotor bolts. Anyone had experience of either? Is the mrp kit worth the extra 35?
It’s for a sid rl with spline two wheels if that makes a difference
for a front wheel you just need the non-disc-side spacer to convert it to boost. The disc side is the same as a normal wheel.
What hub is it? Sounds like DT.
Workmate with a lathe has done 2 x 5mm spacers for the hubs, I've used old 6-bolt to centrelock adapter with filed off centrelock part, bought some standard, longer bolts and it worked a treat! I'd go with ebay special.
Yeah its a dt swiss. can't see any advantage of the mrp so gone for the velosolo ones as reviewed on stw
