Pretty sure that this can't be done but can someone confirm please? Hope hub.
Thanks
Hope sell end caps in various sizes to fit all the different axle standards if that’s what you mean.
Remove 15mm end caps. Push in 20mm ones. It’s that easy
Ah, seems it is possible!
 https://www.rushcycles.co.uk/m50b7s472p9723/HOPE-20mm-Conversion-Kit-for-Pro-2-Pro-2-Evo-Pro-4-front-hubs
Cheers doc! Really clever design actually, even found a kit in the garage!
Yep. I’d forgot about the little circlips that hold them in place, but still a sub 5min job
Yeah, Hope are a piece of piss.Not all 15mms can be converted up- DT240 frinstance has a version that can do all 3 major sizes, but the more common version they sell can only do QR and 15mm.
At the end of the day, it's a hole with some holes in it and some things on the end of the holes with holes in, it's not brain surgery. Just made a bit of a mockery of 15mm is all- "It's lighter"- the axles are heavier, and the hubs are the same but with different, also lighter, endcaps on.
Yes it is doable. I run a fork that can either run a 15mm or 20mm axle and use Hope Pro 4's.
Are you sorted then? Because i put a wanted add up recently had had a few offers i can pass on.
I have a Hope 20mm kit if anyone is looking.
I'm sorted thanks
