15mm through axle r...
[Closed] 15mm through axle rigid fork
13 Users
Anyone know of such a thing? The thought occurs it would solve all the (alleged?) issues with discs, QR skewers & rigid forks.
Andy
Posted : 25/07/2010 7:40 pm
I'm working on one for release this autumn. It'll be carbon too.
Posted : 25/07/2010 7:42 pm
Will there be a tapered steerer option?
Posted : 25/07/2010 7:47 pm
brant - Member
ears prick up at that, currently resisting the urge to do the ss up, dont make it harder!
Posted : 25/07/2010 8:18 pm
At some point.
Posted : 25/07/2010 8:21 pm
Brant - any further detail (pics, weight limit, price, release date, etc) on this?
Posted : 17/10/2010 2:57 pm
Ahh. Thanks for that. Chavtastic colour schemes!
Posted : 17/10/2010 3:59 pm
Hi Mogsuncle.
You emailed me, but I thought i'd reply here.
>Have you got any further details on this (estimated price, weight limit, release date, etc)?
Price - circa £200-£250ish
weight limit = none
release date = about 3-4 months.
Posted : 17/10/2010 4:33 pm
Cheers Brant. So are those your forks badged X-Lite in the link paulS posted? Your profile says you design for several companies but not that one.
Posted : 17/10/2010 5:45 pm
Brant - will it be tandem rated? I know of folk who have been looking for a rigid thru axle fork for MTB tandems to use when touring
Posted : 17/10/2010 5:46 pm
mogsuncle - Member
Yes - The X-Lite forks and the Ragley forks share the same mold and inner construction, though the Ragley ones gain a double ply Kevlar layer on the outside cos I wanted that for a trail fork.
I've updated my "designs for..." in my profile, and sorry for the confusion.
TandemJeremy - Member
It's not tandem rated as the amount of force you can generate braking hard on a tandem is ludicrous and I just don't fancy doing the sums or the tests. I'm sure they'd be fine, but I'd rather not go recommending them to people for that purpose.
Posted : 17/10/2010 6:14 pm
Fair enough brant. I'm sure you would sell one or two of them which would make it all worth while 🙂
Watching the forks on our bike bend a couple of inches under braking is rather frightening
Posted : 17/10/2010 6:19 pm
Okay. Apologies for the cheeky comment about the colour scheme! Are there any plans for a more 'understated' looking version?!
no forks for me for the puffer then 🙁
coming round to the idea of 15mm axels now that stupid hope skewar lets me down in corners no matter how tight it is - going to put a shimano on for now.
Posted : 17/10/2010 6:43 pm
 Kit
So, er, what happened with the 15mm bolt through carbon forks? All I can find online are new stories from last year...
Posted : 04/10/2011 11:58 am
 Kit
Bump 🙂
Posted : 05/10/2011 8:17 am
Niner have the new rdo fork which has a 15mm maxle, taper only though 🙁
Posted : 05/10/2011 9:09 am
on those carbon forks with metal crowns the fork ends just melt off with a bit of heat. stick 15mm pace dropouts on?
Posted : 08/06/2012 1:47 pm
Bumpity bump:
[url= http://www.chainreactioncycles.com/Images/Models/Original/64390.jp g" target="_blank">http://www.chainreactioncycles.com/Images/Models/Original/64390.jp g"/> [/img][/url]
Now available. Anyone got one?
Andy
Posted : 22/06/2012 6:26 pm
What length are those? I've got 440s on a Transition TransAM, the longest 26" forks I could find, and they're too short for a frame designed for suspension forks - BB too low, headangle too steep.
Need 460 or 470mm forks, are these similar?
Posted : 22/06/2012 6:52 pm
paulrockliffe, I use Exotic 29er forks for just that reason despite having proper wheels.
Posted : 22/06/2012 6:55 pm
Paul, from the blurb: "The XF 11 will come in Short 440mm, Long 455mm and 29er 470mm lengths."
Posted : 22/06/2012 7:01 pm
As far as I can see from the CRC listing (to which the image is linked) there are only 455 & 470mm lengths available.
Andy
Posted : 22/06/2012 7:06 pm
Have also found the [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=64387 ]Ragley 15mm[/url] fork in 440mm - IIRC it's the same mould.
Andy
Posted : 08/07/2012 8:40 am
