Does anyone know of any SRAM or other 155mm. mtb cranks in stock?
Oof. Might be better looking at 175/180 and getting them drilled and tapped.
https://www.sjscycles.co.uk/cranks/150-thorn-10464-pcd-triple-crankset-mk2-black/
Showing as in stock.
Good point Scotroutes. I know they have to be a solid crank to be drilled.
wow, those are some expensive cranks for (what I think will turn out to be) a kids bike.
If you’re happy to use Amazon, the SUNTOUR XCT JR Are in stock. I’ve got some on my kids bikes, when you ditch the heavy chainrings, they’re not a bad weight.
£30 crankage - just fitted these to an udderlet's bike. Seem pretty sound square taper jobs for a smaller rider, and they do 150 and 160 options - which may or may not suit your need.
I got some suntour ones for my boy at Bikester here in Sweden. Sure the uk site will have them
https://www.bikester.se/sr-suntour-krg-xct-jr-t-202-chain-set-152mm-M153971.html?vgid=G820577
A mate tapped Truvative 5D's for my lad. They must be pretty cheap if you can find some.
I'd suggest drilling and tapping a set of 175's to 155mm would not be the best choice. That'd leave what, 5mm of material at the end of the crank?
I'm pretty sure NX is aftermarket, but they did SX as OE cranks.
The SX were absolute boat anchors though, the NX weren't light either. I swapped my kids 155 SX out for some alloy spindle Samox M2 cranks which is what Vpace and Trailcraft source. Spawn use the same crank with a steel spindle.
Theres also Prowheel making 155mm cranks
All 3 are out of stock though. Presumably factories are trying to catch up on priority sku's and the brands have zero extra
