142 x 12 to 148 x 1...
[Closed] 142 x 12 to 148 x 12?
2 Users
 benz
So, eying up a new frame onto which to build existing components.
The only issue is that my wheels (and forks) are non boost.
So, any ideas if possible, through the addition of axle and spacers whether I could utilise my Superstar Switch Ultra (Novatec 882) hub rear wheel?
The Sonder Evol is the target.
Of course, if anyone can save me some £ and has a mint small-ish 650b FS frame which can take 160mm travel forks and is 142 x 12, then that would be interesting...
Posted : 13/08/2019 1:13 pm
My new boost rear wheel has just arrived. The 3mm disc spacer and 2x3mm wheel hub spacers I was using until now are yours for £7.50 posted if you want the easy way out.
Posted : 13/08/2019 1:59 pm
 benz
Sounds like a plan.
Will contact you by IM.
Thanks.
Posted : 14/08/2019 7:58 am
