135mm rear frame sp...
[Closed] 135mm rear frame space 142mm thru axle puzzlement
2 Users
me confused - so I took a kinesis cx disc wheelset with qr's off a kinesis pro6 which has 135mm rear spacing - removed the qr adaptors and am now running it on a frame described as 142mm thru axle no problem - so why is the axle described as 142mm? and why I am confused about which wheels I have will fit (with qr adaptors) 135mm spaced frames - is it just that when you take a wheel that is 142mm thru axle add the qr bits it becomes 135mm?
Posted : 14/05/2017 12:44 am
Effectively yes, the QR pokes through the dropouts whereas the 142x12 sits flush with them.The internal width is normally added by recessing the hanger a little on each side. That is if the QR slotted into the 142 but now slightly more confused as I type it...
From Spec
Posted : 14/05/2017 1:00 am
cheers Mike that diagram helps - terminology is the problem axle length versus spacing - these are not one and the same as the thru axle sits in a pair of recesses though the effective frame spacing and chain line issues or non-issues stay the same and the thru axle wheels i want to put on a qr 135mm frame will work once I can find someone that has the converter in stock
Posted : 14/05/2017 9:55 am
