Tempted to update my aged singlespeed Orange R8 to 1x12 using the SLX bargain on Merlin at the moment.
I'm away from the bike / home at the moment but the rear wheel is a Shimano XT circa 2013.
Will a modern Shimano 12sp cassette fit or am I thinking wishfully?
No go. To get 12s to fit, Shimano invented MicroSpline. 11 is your max on HyperGlide, as per older XT.
Balls! Thanks for saving me the hassle though.....
I think that there are other 12speed cassettes that will fit though?
Yes you can fit a 12 speed cassette to a 11 speed freehub
You need a Sram SX or NX 12 speed cassette, these still use Shimano's hyperglide freehub
You can also use Brand X 12 speed cassette's (looks like a Shimano cassette) and loads of other brands 12 speed cassette's just not Shimano's
The Sram ones are 11-50 the Brand X are 11-50 and 11-52
Shimano 12 speed road cassette's are hyperglide so work fine on a 11 speed freehub, the ratios are closer together but you wont get a large gear like a 50T
https://uk.redbrain.shop/p/00710845818011?utm_source=google&utm_medium=css_organic
https://www.highonbikes.com/products/brand-x-12-speed-mountain-bike-cassette-hg-fitting
https://www.merlincycles.com/sram-sx-pg-1210-mtb-cassette-12-speed-280318.html
Shimano roadie stuff will fit, I’ve got
https://www.merlincycles.com/shimano-105-r7100-cassette-12-speed-271625.html
Interesting.... So, would the above basket work? I'm not sure on what chain length to go for.
Thanks for the replies so far.
The above will work. Check how shimano measure 12sp chain length
Also i think you may need a different tooth profile 12sp chainring?
Nah, chainrings will work with 10-11 & 12 speed chains
It would but I'd make changes.
I'd go xt shifter as this makes the biggest difference to shift quality feel £31.50
Then go for the pg1230 cassette to save quite a bit of weight over the 1210 version. £59.99
Then a kmc x12 chain as they work great and are very corrosion resistant £20.99
Finally an m5100 rear mech as they work perfectly and are a lot cheaper than slx for essentially no difference in functionality £33.99
Cheers, XT shift is out of stock for standard bar mount. Deore mech is 11sp, rather than 12sp?
Thanks for confirmation my basket will work - good tip on the cassette though.
Don't think my mild OCD could cope with a black and silver chain! One or the other...
Basket would work.
Sunrace also do 12speed cassettes that fit on a Shimano HG (11speed/oldskool) freehub.
XT shifters ARE nicer!
Looks like I should be shopping around for XT shifter then!
Will do.
Thanks for the help all.
They're the same and interchangeable. Just marketing.
Is that so?!? Well, everyday is a school day.
