120mm bolt through ...
[Closed] 120mm bolt through air forks
7 Users
other than the new reba which i'm almost set on wat else should i be looking at, currently running a 07 uturn air revelation but it could be stiffer for a 6'2 13 stone not paticularily smoth rider who loves rooty rutted trails
Posted : 22/04/2009 10:35 pm
Just bought the 'Absolute' version of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=21345 ]these[/url]. Lovely forks (think I had the last 120mm pair off CRC and distributors have no more stock). If you don't mind 20mm less travel check out my 2 week old 100mm hex axle Minute Comps on a well-known auction site 😉 Coil sprung (hence the sale - even a soft spring was too hard for me) but alu steerer so same weight as their air replacements.
Posted : 23/04/2009 8:19 am
I've got the reba bolt thru's and I'm over 14 stone... no problems here, they are plenty stiff.
Posted : 23/04/2009 8:28 am
14st, 6' and loving my new Fox F120 RL QR15's...plush as a plush thing on a plush day, but really direct steering.
Posted : 23/04/2009 8:32 am
I've been running a set of 145mm Nixons since xmas. I had them apart last night to tweak the shim stack in the damper and I have to say, they're a step up internally from those I've had in 2005 - as high quality of Rockshox and Fox.
Just really a note not to discount Manitou on reputation. (I'd personally stick to the TPC+ version though!)
Posted : 23/04/2009 8:45 am
air u-turn pikes?
Posted : 23/04/2009 9:29 am
Rebas are the best if you only need 120mm imho. For extra stiffness the Revelations can be changed internally to 120mm (and i am liking the look of those new 2010 ones) for not much extra weight.
Fox QR15 are worth a look too
Posted : 23/04/2009 10:07 am
