120mm 15mm 29er For...
[Closed] 120mm 15mm 29er Fork to Replace Rochshox Reba's
4 Users
I'm looking for a 120mm 15mm 29er Fork to Replace Rochshox Reba's which, according to the Local Bike Technician, are knackered beyond economical repairs.
So far I have seen this for £130:
http://www.chainreactioncycles.com/rockshox-sektor-tk-solo-air-forks-15mm-2015/rp-prod158977?gs=1&utm_source=google&utm_term=&utm_campaign=Chain+Reaction-UK-PLA-PLA-All-DT-SE-Shopping+QLB+Product+Desktop&utm_medium=base&utm_content=mkwid|sGIO0sbVU_dc|pcrid|161846717734|pkw||pmt||prd|583579UK
Which is about the price I want to spend but they're a lot heavier and they're 140mm when I'm after 120mm.
Anyone know anything else of around that price that might be more suitable ?
Posted : 24/07/2017 10:10 am
If you have no luck buying new I have some X-fusion slides for sale. 120mm travel, tapered steerer although it is fairly short at approx 170mm.
Posted : 24/07/2017 9:01 pm
How knackered actually are they? You'd be surprised what's fixable on a set of rebas as long as the stanchions aren't buggered and there isn't slop in the bushings.
Otherwise that's a big step down - you'll do much better with a decent set of second hand ones.
Posted : 24/07/2017 9:07 pm
They're losing air but main problem is with only 60psi in them they feel stiff as hell. You can push down on them really hard and it takes a lot to get them to move. But despite the very stiff initial movement, they still bottom out very easily on any bigger hits!
I can't remember the technical details that the Local Bike Technician told me but he said he'll never be able to get them to 100% again, maybe 60-80% of what they were when new. He said it will be £80+ and chances are the forks might be back in the same situation again 3-6 months later. Finally he recommended those aforementioned forks to me.
That's what I've been thinking. Saw a Rockshox Recon Solo Air 120mm on Ebay, hardly been used, £150-£200. Something like this looks like it might be a better option.
Posted : 24/07/2017 11:32 pm
I'm not sure how much shorter 170mm is than my Rebas I'll have to measure them. I've got some riser bars though which could compensate for the shorter fork so I could be interested. What price are they and how much use have they had?
Posted : 26/07/2017 4:01 pm
Not a huge amount of use - 30 odd rides over the past year. You could have them for £130 posted.
I can email you pics if you like.
Posted : 26/07/2017 8:40 pm
I'll have a check tomorrow to see if the short steerer will fit the frame.
Do these Forks require a Disc Brake size of no more than 180mm? I'm think my front disc is 200mm but I'll have to check.
Do they have 15mm through axle and are they for a 29er?
Posted : 29/07/2017 11:44 pm
15mm axle and 29er specific yes. Just googled and max rotor size is 180mm. Given second hand you'd not be voiding any warranty though.
Posted : 01/08/2017 9:05 pm
Just measured steerer - 168mm. I'm going to relist them in the classifieds if you don't want them.
Posted : 01/08/2017 9:31 pm
Hi
See this also in classifieds
http://singletrackmag.com/forum/topic/fs-reba-29-120
Not mine by the way and don't know the seller.
Steve
Posted : 02/08/2017 6:43 am
