12 and 3/16ths of a...
[Closed] 12 and 3/16ths of an inch - time for a new chain?
4 Users
Been getting a bit of creaking and pinging from the chain recently. Did the old "measure 12 half links" routine and got 12" 3/16ths.
So new chain required apparently (I could probably have guessed that from the fact all the bushings spin and rattle) but do I need a new cassette too?
Some sources say definitely - others say not really. It doesn't look tooo shark-toothed yet, but there are a few burrs developing on it.
Posted : 10/09/2012 10:54 am
Buy a new chain, if it works, you don't. If it doesn't, you do.
Although you probably do.
Posted : 10/09/2012 10:55 am
Hmm.. fair enough.
It's my commuter so I'm not overly keen to spend money putting anything shiny and new on it before winter.
Posted : 10/09/2012 10:57 am
Nah it is utter boobbins IME
My two worst
& spped chain using 8 sped shifters and new 9 sped crank - chain stretched beyond words - worked fine [ indexing was bit iffy in the middle]
Road bike 10 thousand miles + on original everything
tested it recently as I think all this change drive train is bobbins [ and i am bit sad 😳 ] and fine with a new chain, fine with a new cassette using the old chain - did not bother changing the front rings but I was tempted to try it with new rings but just assumed it would be fine
No one has ever [s]managed[/s] bothered* to produce any research when I challenge them to on threads like this.
* i am sure the maufacturers have
Posted : 10/09/2012 10:59 am
Ah Singletrack - always five sides to any story 😀
Okay sounds like I might as well buy a new chain but run the old one till the skipping gets bad.
Posted : 10/09/2012 11:19 am
http://pardo.net/bike/pic/fail-004/000.html
Posted : 10/09/2012 11:39 am
Interesting article, cheers (Phil?) Macavity
Posted : 10/09/2012 12:34 pm
