11 Speed Rear Mech ...
[Closed] 11 Speed Rear Mech & 10 Speed Shifter
4 Users
So my wife's rear mech ended up in her wheel at the weekend, I think she caught a rock with it. Her bike was set up as a 1x10 with a 11-42 sunrace cassette. Would be be ok to get a 11 speed rear mech that's designed to work with the 42 tooth cassette but use it on a 10 speed shifter (SRAM xo)?
The X9 she had on there was fiddly to set up as the b limit had to be screwed far in which meant the cage didn't bend forward much meaning a longer than optimal chain length.
Posted : 03/10/2017 8:40 pm
Got slx 11spd mech and 10spd zee shifters on the big bike, b screw clearance is no problem but the different pull ratios can make either end a bit chattery it works ok but not as slick as 10/10 or 11/11
Posted : 03/10/2017 8:48 pm
I take it your using a 10 speed chain? That was my other question as the chainring does both.
Posted : 03/10/2017 9:12 pm
Works great for me. Xt 11 speed medium cage rear mech. Sunrace 10 speed 11-46 and xtr shifter.
Posted : 03/10/2017 10:47 pm
An 11 speed Shimano derailluer works with a Shimano 10 speed shifter. SRAM combos I have no idea.
Posted : 03/10/2017 10:52 pm
