11 speed quick link...
[Closed] 11 speed quick link on a 10 speed chain
6 Users
D'oh, stuck the wrong quick links in my pack. Will I die?
Posted : 23/09/2016 11:42 am
Aren't 11 speed chains narrower than 10 speed? If so I doubt that the link will fit
Posted : 23/09/2016 11:51 am
Probably won't die, but may be in for a long walk as above.
11spd is narrower than 10 speed... may not work
Posted : 23/09/2016 11:57 am
ok ta, suspected that might be the case, fortunately there's a Halfords not too far away 🙂
Posted : 23/09/2016 12:02 pm
As above, 11spd chains are narrower than 10spd. You won't be able to do the link up.
Been there, walked home.
Isn't it just the plates that are narrower? I think the spacing between the plates is the same. Might be wrong though!
Edit.. explained here..
http://velonews.competitor.com/2016/01/bikes-and-tech/technical-faq/tech-faq-chain-width-explained-compatibility-queries-answered_392163
Inner width is unchanged, outer width is narrower. So an 11sp link could possibly work.
Posted : 23/09/2016 12:07 pm
been there done that
iirc the link went on but was very stiff and the chain kept skipping at that point, or did I get chain suck, can't quite recall - something like that.
Posted : 23/09/2016 1:13 pm
