11 speed chain and ...
[Closed] 11 speed chain and narrow wide chain ring
7 Users
Now I **thought** all 11 speed chains worked with narrow wide rings, but having just tried a SRAM PC1130 on a new chainring looks like I'm wrong 'cos it comes off straight away
had an X1 before.
or is it something else?
thanks
Posted : 02/09/2016 5:18 pm
Umm have you definitely aligned the chain properly so the narrow and wide bits line up with the teeth?
Posted : 02/09/2016 5:20 pm
errr well you know what I've run 1 x 11 for over a year and never even thought about chain alignment! must just have been lucky? chain has been on and off loads of times. so no - I haven't definitely aligned it properly!!
Posted : 02/09/2016 9:43 pm
Somebody once told ne SRAM chains were directional i.e. only work properly one way around! I haven't had any problems with my SRAM chain but may be worth a try.
Posted : 03/09/2016 8:10 am
I use that 1130, has sat fine on 2 different nw rings. Never even considered direction. Could the ring be worn or bent?
Posted : 03/09/2016 9:52 am
@ athy62 did he also get you to check your 'speaker cables' ? 🙂
[url= http://www.wolftoothcomponents.com/pages/chain-retention ]http://www.wolftoothcomponents.com/pages/chain-retention[/url]
edit - nosedive +1 chain ring worn?
Posted : 03/09/2016 11:00 am
what make is the ring?
I recently tried a 11spd chain on a On One NW ring and it wouldn't work, but a Superstar ring was fine (KMC X11 chain).
Posted : 03/09/2016 11:29 am
Isn't the On One Ringmaster only 7/8/9/10-speed compatible, going on the blurb?
Not that I have any explanation as to why 11-speed would not work with it! 😉
Posted : 03/09/2016 3:38 pm
brand new Hope chainring
haven't got to try it again today
Posted : 03/09/2016 7:32 pm
