11 sp Shimano front...
[Closed] 11 sp Shimano front mech on gravel bikes problem.
4 Users
Anyone got a fix for this yet ?
Problem is that the new long arm front mechs interfere with any tyre over 38mm wide, ruling out all the best rubber.
A fix would be great, maybe there's a campag / SRAM / something else out there that works with the brifter ?
Or has anyone had luck with a Dremel ?
Does anyone know if Shimano will be coming out with a fix ? Hopefully backwards compatible.
Thanks
Posted : 13/05/2016 9:20 am
There is a SRAM solution, its called 1x11 🙂
There is also a Shimano solution, its called understanding how to correctly design your frame, rather than making the chainstays so short the FD arm hits the tyre.
Posted : 13/05/2016 9:40 am
Run a boost crank? Chainline would be a bit off but it would be ok.
Posted : 13/05/2016 10:16 am
Boost will make it worse. It's the lever arm that catches the tyre.
Boost means it'll (quite possibly) catch on both rings.
Posted : 13/05/2016 10:33 am
It's not too bad on my Diverge which has a road(ish) chainline but on my mate's CdF it's rubbish as the frame would accommodate much larger tyres (which he had purchased...)
Posted : 13/05/2016 11:50 am
