Newbie fork fiddler here so go easy 😂
I'm getting confused on the Sram site but I need this spring to change the travel on my 2013/4 29er Rebas to 120mm.
Any ideas if this part number is used in other fork models?
Thanks.
Looks like it's the same for SID-B forks and both 27.5 and 29er Rebas.
and from memory the SID were the same as the 32mm revelations.... same service manual
I've got a spare airshaft for the 32mm revs that grannyring can have which is 140mm on the 27.5's and if its not exact then I suspect either this or the spare 150 27.5 revs with the top swapped off his existing one would be the same.
Bit of an update.
Ordered this airspring and it turns out that it's the same length as the one fitted in the forks so why am I getting just over 100mm travel, the forks are 120mm...?
They have been well looked after by the look if it.
Reba RL-A3 S/N 42T31433825
Any ideas ta?
