11-40 with road shi...
[Closed] 11-40 with road shifters?
6 Users
Did I imagine it or did problemsolvers make a pulley to convert newer bifters to mtb cable pull?
Posted : 20/11/2016 1:25 pm
http://www.jtekengineering.com/shiftmate/shiftmate-8a/
Posted : 20/11/2016 1:32 pm
 tang
Wolf tooth tanpan and roadlink have me rolling on a 11-40 XT clutch and Ultegra shifters.
Posted : 20/11/2016 1:39 pm
Very similar setup here - although only 11-36 and no roadlink - feels like it was meant to be! I ran an 11-40 for a ride and it worked but moved that back to the mtb as need it more there!
Posted : 20/11/2016 2:28 pm
If your starting from scratch then SRAM do this off the shelf.....
The cable pull being the same for road and MTB on SRAM
Posted : 20/11/2016 3:23 pm
So why does this exist then?
http://www.jtekengineering.com/shiftmate/shiftmate-9/
Posted : 20/11/2016 3:40 pm
Cheers, thats just what I was after.
As for SRAM, yes I believe it does work off the shelf, but I have shimano on my other bikes.
Although thinking about it I have a set of crash damaged 7800 levers, so I might canibalise them and an old 9s mech which would give me 11-40 with the roadlink and an expander cog?
Posted : 20/11/2016 4:20 pm
Good question. To cover myself I'll rephrase my statement
With SRAM you can buy a road shifter and mech capable of running 10-42 cassette
https://www.merlincycles.com/sram-force-cx1-11-speed-hydraulic-disc-brake-groupset-83682.html
I'll do a bit more research later
This also suggests its all 1:1. What am I missing?
https://www.sram.com/sram/mountain/technologies/exact-actuation
Posted : 20/11/2016 4:31 pm
I think everything up to 11 speed road is 1:1, 11 speed mountain is something like 0.8:1, so you need a special mech to do 11 speed road shifter with 10-42.
Posted : 20/11/2016 6:16 pm
Ah, it's called 'x-actuation'
Posted : 20/11/2016 6:18 pm
Thanks I get it now. Upto 10 speed SRAM is mix and match
At 11 speed the difference is that SRAM make a CX specific rear mech that will work with a 42 cog and road shifters
Posted : 20/11/2016 8:18 pm
