10speed Conversion ...
[Closed] 10speed Conversion Problems
5 Users
I'm just after a few tips that may help remedy chainring noise. I recently converted my shimano setup to 1x10 -34T Hope chaining mounted to Deore Cranks with 11-36 on the rear and 10spd chain. When I shift up towards the larger 3 sprockets at the back, the chain seems to stretched across at a sharper angle, causing chainrub/jumping on the chainring. Would the Hope alloy chainring thickness be the issue? as i experienced no problem using a steel 34T shimano on a 1x9 setup. Could I use spaces between the crank and chainring to reduce the angle and hopefully reduce the noise? Any thoughts would be really useful.
Posted : 03/09/2012 10:20 pm
Have you put the chainring in the middle position?
Posted : 03/09/2012 10:21 pm
Yes, its in the middle position, with a Gamut bashguard on the outside.
Thanks.
Posted : 03/09/2012 10:24 pm
Then I have absolutely no useful suggestions!
Posted : 03/09/2012 10:58 pm
How many BB spacers do you have on the drive side?
Taking one off and fitting it to the lhs could improve your chain line.
Posted : 03/09/2012 11:04 pm
I get this regularly on brand new bikes, sounds like the chain rubbing the mech cage even though it's clearing. I put it down to the wider chainline used for clearing wider tyres on the more recent kit, not a lot you can do on HT2 type set-ups other than offset the entire chainset by playing with spacers. If you weren't using a single speed specific chainring before, it may explain why it was less noticable, as it's teeth are shallower and more chamfered to aid changing gear(sometimes Shimano do actually know better than us) 🙂
Posted : 04/09/2012 7:02 am
I've used a Hope chainring on my 1x10 setups (both SRAM and Shimano) without issue. I use an N-Gear Jumpstop and whilst it makes a bit of noise against the Jumpstop plate when on the largest sprocket it's been fine.
My other bike (1x9) used an FSA 'DH' chainring that had slightly thinner teeth compare to the Hope.
Posted : 04/09/2012 8:05 am
