10sp MTB and road m...
[Closed] 10sp MTB and road mix.....
7 Users
My Datum currently has a Shimano 105 10sp groupset. The cassette is 11-28 10sp. It has a compact chainset.
If i want to put a 10sp mtb cassette on the rear, an xt 11-36, do i need a 10sp mtb mech or a 9sp to work with the 10sp STI units?
Are there any problems with this idea? I have a new xt 10sp cassette in the the spares drawer, and a new chain too. I also have a 9sp xtr rear mech lying around. It seems like it would be good for my alpine trip...
Posted : 16/04/2018 1:16 pm
So long as the shifter and mech are both either 10sp road or 10sp mtb (not a mix) you shouldn’t have any problems so long as the cage has sufficient capacity for your new gear range and can cover the cassette without crashing into it.
Usual sum ((big-little)+(big-little)) to work out required capacity.
Posted : 16/04/2018 2:00 pm
Yes, 9 speed Shimano mech has the same pull ratio. I have this setup on my Croix de Fer.
Posted : 16/04/2018 2:05 pm
If you want to run a 10 speed MTB mech on a 10 speed road shifter the wolftooth tanpan job does a very nice job.
My understanding is you can get a 9sp MTB rear mech on 10sp road shifters (edit: as above) but I've not tried it myself. 10 speed gets you a clutch if that matters to you?
Posted : 16/04/2018 2:12 pm
I've run 10spd road STI and 9spd MTB mech in the past (10spd cassette, obviously) - works fine.
This was on 11-34 though. The 9spd mech 'should' be okay with 36 but I haven't done it myself.
Posted : 16/04/2018 2:15 pm
 Andy
Currently running 2 bikes with 10 speed shimano 105 road shifters, 10 speed 11-36 shimano xt cassette and 9 speed shimano mtb rear mech. Works perfectly.
One is using an xt 2 x 10 chainset, thats a medium cage xt m770 mech. The other uses a 105 50/34 chainset, thats a long cage xtr m970 mech
Posted : 16/04/2018 2:17 pm
As above, i run 10spd 105 with a 9spd xt mech, works perfectly.
on my mtb i use dura ace bar end shifters (10speed) pulling a 9 speed xt mech, over a 10speed slx cassette.
works perfectly.
Posted : 16/04/2018 2:23 pm
Thats great, thank you!
Posted : 16/04/2018 8:26 pm
