igm - MemberEven if they're beyond fixing...
1. Chain stay protection
2. Rubber shims
3. Bed creak prevention
4. Boiler repairs (yes really, patched up a leaking combi with inner tubes and a dry wall anchor - it held pressure)
Etc...I'm sure there used to be a 101 uses for an old inner tube thread on here
Just for IGM:
5. I cut em into rings to hold my hockey stick onto my glove so it doesn't float off if I drop it.
Bung em in a tree to annoy winston 👿
co2 canister wrap ... no more frozen fingers !
A yes, waterproofing battery packs was another.
I like to clutter up my garage with them.
Wrapping around heavy duty chain locks to stop them marking your frame.
Slings for broken arms.
Tow "ropes" for when your mates cranks inexplicably* fail miles from anywhere.
*I blame him for not tightening the pinch bolts, he is still at a loss to explain how the splines failed and the nds crank am would no longer stay on.
Cut them into rings of varying widths (3-10mm) and chuck them in a pot on your desk- best and strongest elastic bands ever and great for spending hours messing/procrastinating with!!!!
Temporary rainwater downpipes.
A decoration for unloved hedges.
Robust Prophylactic. (Silicone seal one end together)
'Grippy bits' on my roofbars, to stop the canoe sliding off when loading it on the slope that is our drive.
A physics lesson for kids - angry birds for real (29er ultralight works best).
Door restrainer for the kit store at outdoor centres.
well with motorbike ones used to cut into narrow strips and use then to hold your waterproof trousers on your boots, so if you've got thin legs ..........
and you can make your own o rings
wrap around metal gate frames to act as a slam silencer
Plastic waste pipe under the sink, that was slghtly misaligned & wouldn't seal.
Disconnected the joint, stretched a section of innertube over, then reconnected & rolled it back.
Never leaked again. 🙂
The valves can be used for making coke bottle rockets with a track pump.
Wrap thn around an old skateboard deck to act as bindings for your feet. Then
Practice snowboard tricks indoors or on a trampoline
How I hang my kayak and canoe paddles up in the shed.
Garlic clove peelers
Makeshift cosh (in case of a lack of Bombers situation) - just add snooker ball.
They're great as a gas meter bypass pipe.
bar tape
Old guy who visited the shop I worked in used to ask for punctured tubes out of the bin.
One time I made the mistake of asking what he used them for.....
He used them on camping trips. He'd cut them open into a length of tubing, and at night he'd slip one end over his old fella, and stick the other end out of the tent so that he didn't have to get up in the middle of the night.
Had always found him pretty creepy beforehand and this confirmed my feelings.
pitchak indeed
Old guy who visited the shop... he'd slip one end over his old fella
How old was old guy's old fella?
Cut into bands for making hand brakes (brake lever pulled back to the bar) for when you're touring. Stops that 'ah fkcu' moment as your bike rolls away and falls over.
Mudflaps for protecting front mechs and suspension pivots from mud/spray. Stretched around bar-ends and seatpost to hold steering straight whilst you walk seven miles back home with a totally seized rear hub (freehub bolt worked loose).
Bones - dunno, but expect it's quite wrinkly.
Cush drive repairs/maint on a Yamaha XT660X
Kia Soul squeaky seat reapirs, cut out a square, criss cross a hole in it, then have 1 below the base plate and 1 between the seat and bolt...creaky seat, now silent.
As a means of lessening the load/weight when doing hangs and pull-ups on the fingerboard.
Sounds cool! Can you explain how please?matt_outandabout - Member
garlic clove peeler - How does that work ?
slide 5" of inner tube over crank arms, to preserve decals/paint from wearing away
wrap around an old wonderful apple tree to then tie a clothes line to the tree, gives protection to the tree/bark.
Cut them to make new rings to hold cree lights on. Wrap a strip around the bar to protect the finish and stop the lights slipping.
Reverb mud/grit guard
Anti splinter protection for kids tree house - sliced into strips and nailed over the "rubbing points" where they climb up and slide down past rubbish softwood overlaps.
Shrub/ornamnental tree straighteners - tie to trunk/stem and apply tension in required direction, stake other end to ground, wait a season or two and bobs your uncle! 😆
mtbel - MemberSounds cool! Can you explain how please?
Cut out the valve with only a slight 'flare' of rubber left on the base of it. (Trial and error will show how much you need to leave on).
Drill a valve stem +a bit sized hole in coke bottle cap - insert valve from inside.
The 'flare' of rubber should hold the valve in place, but should eventually come out under pressure.
Screw top back on coke bottle.
Attach the track pump and get pumping...Experiment with a bit of water in the bottom of the bottle for added boost (and soaking).
If that does not work so well, replace cap with a drilled wine cork and valve shoved through.
[img]
[/img]
Cut a 3 inch length from the tube.
Insert garlic clove
roll between palm of hands.
Voila*
*I've never tried this
How about ghetto rim strips for larger wheel diameters?
Ought to work, the Stans fluid would seal any punctures.
How about ghetto rim strips for larger wheel diameters?Ought to work, the Stans fluid would seal any punctures.
I use this on non-Stans rims, needs 20" Schwalbe (has threaded metal stem for Schrader) inner tube.
I use mine in the back of my car, loop hitched over the grab handles, one each side. Holds bikes upright in cars that only require front wheel removal to fit in upright (people carriers etc). The other end over the frame and over a pedal etc.
Cur the valves out and use them in a tubeless wheelset. Saves about £15
Use 4 or more of them, maybe make one of those 'adult' swings...
neil the wheel - it does work.
I use old inner tubes for tree ties, and in the car for generic ties/straps.
We used them to stop our rabbit nibbling through the cables of our garden lights
Thanks Matt.. the kids... ahem... are gonna love this 8)
