100mm 120mm wheelse...
[Closed] 100mm 120mm wheelset
6 Users
I have just purchased a trek 2nd districk frame that has 100mm front wheel spacing and 120mm rear
I am looking for a wheelset for general use but all seen to be for track bikes
Any suggestions of a wheelset?
https://www.planetx.co.uk/i/q/WPGIPIFI/gipiemme-pista-fixed-700c-clincher-wheelset
I have looked at these but they seem really heavy but atleat there cheap
Posted : 23/11/2017 11:26 am
Thats some serious heft @ nearly 2.4kg for that wheelset - but they are cheap!
Look for some track hubs ( 💡 GoldTec) & build with Mavic Open Pro rims?
Or this: https://www.sjscycles.co.uk/hubs-other/black-32-surly-ultra-new-track-fixedfree-rear-hub-120mm/ on this https://www.sjscycles.co.uk/rims-tape/32-mavic-open-pro-c-700c-622-rim-cd/
SJS can do you a wheelset build.
Posted : 23/11/2017 11:34 am
Halo Aerotrack and Aerorage are pretty good for the money (£150) and weigh around 1900 grams.
With a 120mm rear hub you will be looking at wheels labelled as track but they are fine for general purpose use (as long as they have a machined brake surface which most do)
Posted : 23/11/2017 11:35 am
Velodrome shop
https://www.velodromeshop.net/track-wheels/
and Dolan Bikes
https://www.dolan-bikes.com/bike-components/wheels.html?dir=asc&order=price
both have excellent ranges, from the very reasonably priced up to 'you can get a car for that' craziness
Posted : 23/11/2017 12:03 pm
Velodrome shop helpfully make sure they state in the product description whether or not there is a braking surface.
Posted : 23/11/2017 12:05 pm
They don't however point out that you are unlikely to receive what you have ordered/paid for.
Only worth using if you are in no rush at all for what you have ordered as you may never get it.
Posted : 23/11/2017 12:23 pm
Oh dear are they a bit crap? I didn't realise!!
Posted : 23/11/2017 12:48 pm
I used a standard QR Road wheel on the front of my fixie till I changed to a disc fork (and now use a pretty standard QR 29er MTB wheel)... So you can use almost any 622 rimed wheel on the front
Having the front QR potentially saves some faff if I were to get a front wheel puncture...
120mm is also a pretty common standard for track/SS/Fixed bikes, I've got a Rigida Rim built on a Cheap hub I bought from Planet X, I keep a 15mm spanner fixed to the frame in case I need to remove the rear wheel for a flat... You can get 120mm QR hubs but they're rarer and in theory more likely to slip under load, handy for punctures though...
I'd look for 'Truebuild' wheels/wheelsets online maybe, they tend to be cheap...
Posted : 23/11/2017 1:03 pm
They haven't got the best reputation. I always suspect a shop that has such a large list of obscure stuff for sale. Guessing their model is to order from their supplier when they get an order which can go wrong quite often (see Tredz!)
Posted : 23/11/2017 1:16 pm
I've used velodrome shop twice before. Once I emailed beforehand to check, once I didn't. Both times the order arrived the next day, no hassle.
Posted : 23/11/2017 1:39 pm
There's a fair few disgruntled customers amongst the happy ones on TrustPilot
https://uk.trustpilot.com/review/www.velodromeshop.net
Posted : 23/11/2017 1:58 pm
