10 speed wide range...
[Closed] 10 speed wide range cassettes and mech options
8 Users
Will a GS slx mech work OK with an 11-42 cassette without adding a Rad cage or a Goatlink?
Would a Shimano M8000 rear mech work with a 10 speed cassette and 10 speed Shimano shifter?
Posted : 05/02/2016 10:49 pm
Got a friend with the goat link on his SLX/11-42 set up works well but not quite as well as my set up which has the Rad cage (but XTR rear mech)
Posted : 05/02/2016 10:56 pm
I've got a Rad cage and XT cassette with One-Up 42t expander on my Pitch and it shifts perfectly.
I've been 1x10 with an 11-36 on my hardtail for a while but I snapped the mech this week and the chain/cassette are very worn now. So I've bought a Sunrace 11-42 cassette to try.
I'm sure I saw on here someone was successfully using a M8000 11spd mech on a 10spd set up.
Posted : 06/02/2016 7:27 am
Did the visual check on 11-42 with an XT Mech and it was a no, just too much movement to be comfortable, got the RAD cage and it's fine
Posted : 06/02/2016 7:28 am
Yes, your slx mech will absolutely be fine with the cassette. I've used a few deore slx and xt, none have required special cages!
Posted : 06/02/2016 8:13 am
My riding buddy is running an SLX mech with a sunrace 11-42..... Nothing special needed, just adjust the 'B' screw correctly
Posted : 06/02/2016 8:40 am
 erny
Yes it will be fine, I run my slx mech with a über bike 42 expander and xt cassette. As others have said, adjust the B screw
Posted : 06/02/2016 9:03 am
What Stedlocks said.
I had to remove the plastic cap under the head of the B tension bolt so I could wind it in a bit further.
Works well.
Posted : 06/02/2016 9:08 am
What mike said, remove the little plastic bit under the B screw. I ran an 11-42 on GS SLX for ages. When I snapped it I went to XTR and rad cage, doesn't need as much b tension so shifting lower down is more precise and setup is easier but yes, it will work
Posted : 06/02/2016 10:37 am
Thanks all, I'll take the plastic bit off the B screw and try the standard GS SLX mech.
Posted : 06/02/2016 5:54 pm
