10 speed drivetrain...
[Closed] 10 speed drivetrain with 11 speed cranks
9 Users
Following a bike fit, I need to change the cranks on mrs_m's bike to something shorter. Her bike is currently running a Shimano 10 speed setup, but most of the cranks I can find are now 11 speed. Has anyone run a 10 speed drivetrain on 11 speed cranks, and was it OK, or do I need to look at a full 11 speed upgrade?
Posted : 06/10/2016 4:18 pm
I ran 9 speed cranks on an 8 speed chain
Problem is the 11 speed chain is smaller so it will, I assume.
1. Work
2. Wear Quicker
3. Possibly be a little noisy
Posted : 06/10/2016 4:22 pm
There were some 170mm 2x10 XT cranks in the CRC clearance - about 60 quid with a code.
Posted : 06/10/2016 4:26 pm
It'll be absolutely fine. No reason for extra wear or noise whatsoever.
Posted : 06/10/2016 4:40 pm
I ran 10 speed cranks on a 9-speed setup for a while. No issues at all.
Posted : 06/10/2016 4:41 pm
Thanks all, I am going to give it a go
Posted : 07/10/2016 12:54 pm
I've previously run 8sp cranks on a 10sp and also run 10sp cranks on an 8sp bike.
No issues for either setup.
So I assume you will have no problems.
Posted : 07/10/2016 1:02 pm
My 10speed TT bike came with 11speed cranks as standard
Posted : 08/10/2016 12:50 pm
11 speed slx crank and the rest of the drive train is 10 speed here, zero issues.
[URL= http://i106.photobucket.com/albums/m263/rob_g_clarkson/20160829_161414_zpsxt1rdekr.jp g" target="_blank">http://i106.photobucket.com/albums/m263/rob_g_clarkson/20160829_161414_zpsxt1rdekr.jp g"/> [/IMG][/URL]
Posted : 08/10/2016 4:02 pm
I am running 10speed rings with 11 speed transmission.
No problems whatsoever.
I guess the tolerances between the two are so minute.
Max
Posted : 08/10/2016 6:30 pm
