I've got an XT 9 speed Hollowtech II chain set. Is it possible to run a 10 speed chain ring successfully if I change the cassette, chain and rear mech of course ? Do I need spacers ?
It'll work no bother, you'll just need shorted chain ring bolts
If it doesn't fit, all that should need doing is a small about if filing, to remove the excess from the chain bolt tabs
Cheers guys, many thanks for the positive advice
M770 9 speed will be fine as it came with the later metal + composite middle ring. The older m760 type will need some fettling for the new style middle chain rings.
Thanks Andy. Bad news then as I think mine is the older one !
