10 Speed Cassette -...
[Closed] 10 Speed Cassette - XT or PG1050/70?
5 Users
does anybody have any experience of the new 10 speed sram cassettes? i like the look of the pg1050 cassette though can only find it in 12-36 instead of 11-36 not really a problem assume it will still fit ok...
have xt at the moment, its been ok but not super smooth with either a xt chain or xtr chain....
i know alot of 2x10 spesh stuff and whyte etc come with the pg1050 cassette, so just wondered of any experience...it looks very hollow and looks like it would clear mud/grime quicker than the xt too
Posted : 29/02/2012 10:13 am
anybody any thoughts please? just hovering over which to buy, sway me to stay with xt or try the sram ones...also liked the pg990 when i had 9 speed....just want to know how the 10 speed sram stuff is holding up
Posted : 29/02/2012 12:01 pm
bump for any afternoon crowd
Posted : 29/02/2012 3:58 pm
I've a 1050, can't comment on anything beyong it has 10 gears and they all work. I only use it in the dry and too unfit to notice the lack of an 11t.
Posted : 29/02/2012 4:00 pm
cheers tinas!
guessing the 12t instead of 11t just means its a little easier to pedal on than 11t version? guessing it would fit just fine?
Posted : 29/02/2012 4:31 pm
They will all fit on your free hub, the only different size I believe is when you get to 7/8 speed.
Posted : 29/02/2012 4:42 pm
well, thinking about it......
32/11 = 2.909
35/11 = 2.916
32 to 35t would proably be a noticable difference, but I don't spin out at the moment so don't really care, generaly if I'm in the top 3 gears I'm probably decending which probably means pedaling for ajust a few revolutions then corner/pump/whatever.
Posted : 29/02/2012 4:54 pm
I have a 1070 since October, works. My setup is all SRAM/Truvativ, shifting is spot on. Can't compare to Shimano as haven't used the equivalent 10 speed.
My 1070 chain though went to 1% stretch double quick (it felt), I have another and am monitoring it closely.
Posted : 29/02/2012 5:05 pm
I don't know about 10 speed (I'm always way behind here - running two 8 speed and one 9 speed bike currently!) but in the 9 speed world the XT equivalent in terms of price/weight is PG990 - 970 and 950 are much cheaper/heavier. Check the 1050 / 1070 weights vs XT - if you care about that sort of thing. I changed from XTRM950 8 speed 12-32 cassettes to 11-34 PG990 on the one bike that has actually got as far as 9 speed and the 990 weights over 300g (about the same as 9 speed XT) which was 75g more than the old 8 speed XTR one...
Posted : 29/02/2012 9:42 pm
