10 speed cassette f...
[Closed] 10 speed cassette for xd hub?
4 Users
 benz
New DT Swiss M1900 wheels are 142 x 12 and xd hub.
I believe they have DT 370 hubs.
I need to convert to standard 135mm qr.
Again I believe that this is a simple pull off and push on new end caps?
However, I would prefer to stick with 10 speed as I that is what I have in terms of shifter, mech, cassette - all new and unused rather than go to 11 or 12 speed.
So...does anyone know of an 11>42 cassette which would fit an xd hub?
Alternatively I could just replace the freehub with a 3 pawl Shimano compatible?
Thanks all.
Posted : 28/12/2019 5:16 pm
So…does anyone know of an 11>42 cassette which would fit an xd hub?
As far as I’m aware, the only XD compatible cassettes are 11, 12 and 7 speed.
You can change to an HG freehub though which takes everything.
Posted : 28/12/2019 5:24 pm
 K
I can see if they were something higher spec like 240 hubs it is worth the messing around and spending extra on adapters. So, why not get some wheels that have the configuration you require to start with?
You gain nothing with a 370 over other standard pawl hubs.
Posted : 29/12/2019 8:56 am
Someone may swap their Shimano freehub for your XD?
Posted : 29/12/2019 9:08 am
