1 x10 speed cassett...
[Closed] 1 x10 speed cassette question
15 Users
Planning on running my hardtail with a 1 x 10 set up to replace a tired 1 x 9 Shimano XT mech and shifter. What cassettes do the 10 speed boys run? 32 34 or 36 T .
Cheers Rich
Posted : 18/05/2012 4:15 pm
 mboy
Otherwise, as njee politely puts it, there's no point in running 10spd as you don't gain any advantage.
I ran 11-32 9spd for a short while, I found it limiting. I changed to 11-36 10spd setup, and found just the extra ratio makes all the difference, and I can and have ridden pretty much anywhere with that setup.
Posted : 18/05/2012 4:25 pm
agree with mboy, running 11-36 and find can get up most stuff - run with a 34 chain ring
Posted : 18/05/2012 4:28 pm
32 x 11-36 here, on 29er. Tis fine.
Posted : 18/05/2012 4:30 pm
11-36 with a 36 upfront
Posted : 18/05/2012 4:31 pm
32 - shits all over 36.
Posted : 18/05/2012 4:53 pm
34 x 11-36 here
Posted : 18/05/2012 5:01 pm
Cheers to all.
Rich
Posted : 18/05/2012 6:06 pm
 erny
32 11-36 here but I'm going to change to a 34 up front
Posted : 18/05/2012 6:19 pm
Gets up mountains that does. I find it better for technical climbs as well.
Posted : 18/05/2012 6:40 pm
What mboy said, which as he rightly said, is what I say!
Posted : 18/05/2012 6:47 pm
just moved from 1x9 to 1x10 and going to run 32t and 11-36
Posted : 18/05/2012 7:36 pm
ditto
Posted : 18/05/2012 8:01 pm
 nikk
32t and 11-36 here.
Good for everything except the daftest of crank-me-up climbs, and keeping up with 20mph roadies.
Hardly ever use lowest gear, but with laden bike on multi-day trips up hills, expect to do so.
Posted : 18/05/2012 9:02 pm
11-32 was too low for my taste (on 9-speed but it'd be the same on 10 obviously 😉 ) but also sometimes too high. I'm going to have another crack with 34-36 once I wear out the last of my 9-speed stuff.
Posted : 18/05/2012 9:04 pm
Just to be different 12-36, so there 😛
But mainly because there were more SRAM 12-36 available. Anyway, the 11 end makes no difference to me. The 36 however is very useful. I run it with a 34t.
Posted : 18/05/2012 11:27 pm
12-36 10 speed? That's presumably SRAM's way of forcing you to buy their more expensive cassettes then?!
I run a 36t ring and find it fine, fairly strong rider though.
Posted : 19/05/2012 7:23 am
