Buying a Brompton -...
[Closed] Buying a Brompton - Options
32 Users
I'm about to buy a Brompton, and thought I'd check here for advice before spending that much cash.
I'll be moving to Brighton and commuting to London, so may have some hills at the Brighton end.
Spec I'm considering is S3L; -12% gear ratio; firm suspension and marathon plus tyres.
I'll probably get an O bag though am balking a bit at the cost; and I sometimes overfill an Ortleib back roller on my current commute, so would prefer a bigger bag.
I'll buy it on the cycle-to-work scheme, so don't need to look at s/h.
Anything I should change / think about?
Posted : 27/01/2016 2:07 pm
Mine's an S3L too. Eezy wheels are the only thing I'd say are a must have - whilst as a bike Brompton's aren't too heavy, as a handbag they can get quite tiring and being able to tow the half folded bike around the place (shops, stations) like a wheelie suitcase is much easier.
I found the pedals horrible - I run spds on mine. I'm also not a fan of the 3 speed - gear 1 is uselessly low, 2 is OK for pulling away and hills but spins out too easily, 3 is monstrously high. (I live in Sheffield so also have hills). That's with stock gearing I think (50T ring).
Agree with the firm suspension.
Oh, and Kojaks @90psi for speed. 🙂
Posted : 27/01/2016 2:18 pm
 aP
Make sure you have mudguards, think about getting a dynamo hub for lighting - my front rim is nearly worn out after 5 years and am thinking of going dynamo so that I always have lights.
I wouldn't worry about a rear rack unless you intend to carry stuff on it as it adds a lot of weight and make carrying the bike less pleasant. I only carry mine going in and out of building TBH, the rest of the time I wheel it.
I have an S2 and the gearing tends towards being a bit too low, and a bit too high. However it is light.
Be careful about the O-bag as its not wholly compatible with the s-type if full, I can't really recommend the Caradice S-bag as the buckles aren't very good - looks nice though...
Posted : 27/01/2016 2:24 pm
I would disagree with the gearing comments above, mine has the -12% gearing on the 3 speed and it's great around edinburgh and the top gear is much more useable that way too.
You can always do the Brompton hire for a week to try out what you want first? Look up your nearest dealer with hire on their website
Posted : 27/01/2016 2:40 pm
I made the same move 13 years ago (how can it be that long?!!) There was a lot less choice in Bromptons in those days but if I was buying now I'd get an S3L (though mine is actually the equivalent of the M6L). Hope to see you out on the dirt on a proper bike at some point!
Posted : 27/01/2016 3:08 pm
 km79
Yes, the whole idea of buying a Brompton. Unless you have a penchant for looking ridiculous.
Most things covered above. eezy wheels are very good, mudguards obviously and I would echo the lights depending on where you're riding it. London will obviously be lit and if your ride at the brighton end is as well then I'd definitely get the lights. I didn't and it is more hassle, particularly if when leaving the front light on it gets caught in the fold.
If you want to try an S3 to see if you like the hub then you could always sign up to the Brompton dock. They have the dynamo lights on as well. Only downside is the bikes don't get a huge amount of tlc but fine for trying out.
Posted : 27/01/2016 3:29 pm
A Purple Haze S2L with long seat and firm suspension here. Oh - and the Kojak tyres. They are brilliant and (so long as you pump them up) very puncture proof.
Light it up from the back, front, sides…
Rachel
Posted : 27/01/2016 3:36 pm
I don't find carrying an issue as I keep it unfolded until I absolutely need to. Thus never felt a pressing need for eezy wheels and the like. Going 2 speed rather than 3 saves about 450g which helps a lot. I like the gearing too, low is fine for getting up hills, other is fine everywhere else. Only annoyance is when a hill is not quite steep enough for gravity alone to accelerate you, you can be spinning quite fast to maintain speed.
The Brompton lights have always seemed dire, Knog or similar fit easily and don't get in the way of the fold. Dynamo would be nice, but so much extra weight.
O-bag looks nice but the waterproofing of the regular S-bag has been fine for me so far; it's not like I'd be riding for hours in a downpour like I would on a touring bike so I guess it doesn't matter so much.
Posted : 27/01/2016 4:08 pm
the shimano hub dynamo lights are a good option
Posted : 27/01/2016 4:17 pm
M3L with Marathon Plus here. Love it.
Posted : 27/01/2016 4:27 pm
 aP
And definitely get Marathon Plus tyres - the trade off of not being able to ride so fast will be offset by the annoyance and pain of dealing with punctures. I much prefer fit and forget, then when you do get a puncture eventually you know its time to change them as they're worn out.
I did see Schwalbe Brompton sized ice tyres recently ...
Posted : 27/01/2016 4:41 pm
I've got an S6L with
- Marathon tyres
- eazy wheels
- mudguards
Bought 2nd hand, to use for a few months, 4 years ago. Kept ever since and currently being used for a daily train commute.
If i was buying again I'd possibly get a s2l or s3l as the 6 gear setup is a bit fiddly to use (it's like a 2 speed cassette + 3 speed chainset so you're constantly changing both).
I'd also look at getting dyno lights. Just means you can pick it up and use it without giving any thought to whether the USB lights need charging. Weight not too much of a problem, I almost always just unfold and wheel it around most of the time.
I've got Marathon (rather than Marathon Plus) tyres and don't notice any difference in speed/weight over the standard tyres due to the tiny size of the tyres.
Posted : 27/01/2016 5:05 pm
Make sure you or you LBS can get parts and that one of you can change the pivot bushes. It can be cheap and easy if you know how, but it's virtually impossible if you don't.
I dunno how beast it is for joe public to get Brompton spares but a lot of it is very specific, and you have no choice but to use Brompton parts.
Posted : 27/01/2016 5:53 pm
 aP
Between SJS Cycles, Brilliant Bikes, Condor, bikefix and the Brompton shop pretty much all parts are available now. The only thing that's difficult is the replacement of the pivot bushes as it requires a specialist tool, but the new bushes are available.
Posted : 27/01/2016 6:37 pm
For the ~1/2 kilo weight saving, I went with 2-speed (S2L) over 3 speed. Worth think whether you really need a 3rd gear...
Posted : 27/01/2016 6:51 pm
Got an S3l with cut down Easton risers on it. Best thing I've done. Puts bars right where I want them. Other than that I swapped the pedals over to V12 Mags and stuck a charge spoon on it. Definitely get the marathon Pluses. I couldn't manage with just two gears and use all 3 pretty much equally.
I love my brompton. Ride it more than any other bike, and I'm not a commuter.
[URL= http://i1280.photobucket.com/albums/a491/loddrik1/2014-11-05_11-47-21_zpstiv5e7po.jp g" target="_blank">http://i1280.photobucket.com/albums/a491/loddrik1/2014-11-05_11-47-21_zpstiv5e7po.jp g"/> [/IMG][/URL]
Posted : 27/01/2016 6:56 pm
Wouldn't worry too much about the weight of add ons,
Would definitely recommend dynamo lights, the newer B&M led lights as great!
If you want a rack would get it from new as retro fitting is a pain as you need to replace mudguard to fit as well,
The C Bag is 25litres and I've found to be good, has water proofing but also has a hiviz rain cover included.
I find the standard gearing a bit high, considering converting to 6spd or smaller chainset.
Posted : 27/01/2016 7:23 pm
I used to commute on my Brompton daily - from Surrey up a hill to the station then a short hop from London Bridge to Old Broad Street.
I went for a S2L but got a smaller (50T) front ring - I think for a cyclist this works well - it's easy enough to get up a moderate hill without getting too sweaty and you can spin fast enough on the flat to make decent progress. I don't miss a 3rd gear and it's lighter.
Posted : 27/01/2016 7:55 pm
Like so many things, what's right for you may not be tight for another.
The rack is great for carrying stuff, adds a whole 300gm but obvs stiff needs taken off to fold.
Gearing is important. I find STD gearing too high. Bear in mind it's a pig to ride out of the saddle so low is good.
O bags are small and expensive. I like my T, you can really fill it with the roll top unlike a C.
I have up worrying about weight - even light ones are heavy to carry, and you want it to be able to do what you need when riding. But then I've used mine in hilly areas and for 40m days.
Posted : 27/01/2016 8:21 pm
Thanks all - some really helpful advice - has covered everything I was thinking about, and added a bit extra to consider. Probably sticking with 3 speed and adding dynamo lights now.
@chiefgrooveguru I'll be moving in the summer, so will be looking then for MTB options.
Posted : 27/01/2016 8:59 pm
 Spud
I bought an S2L on C2W last year, regret not having more gears, it's too hilly for my closest station to home. Already downsized the front chainring. Will likely furnish it with the Kinetics 8 Spd kit soon. Love it though, mudguards a must, pedals awful and eat leather soled shoes. Got a mint condition O-Bag from the famous auction site. Jobs a good-un.
Posted : 27/01/2016 9:28 pm
Mrs has been riding Bromptons daily for the last 12 years, from P&R to Oxford centre.
Can't remember when she last used 1st gear. Admittedly no major hills, but if you don't need it save the weight & go 2 speed.
Uses a pair of lezyme lights front & rear. Less faff than the Dynamo she had on her first, which repeatedly failed after a couple of years. Might not be relevant if the've updated the system since.
Marathon Plus on 2nd one, from new. Touch wood no punctures.
Bags! Took one look at the price list and said no way. Ridiculously overpriced. Have a look at Demano recycled bags, from Spain. Specifically the Diagonal Mar. Took a bit of a punt on one, purchasing direct from Demano. No issues, turned up a week later and been great. With hindsight would go with bag rather than rack and save a bit more weight.
Posted : 27/01/2016 9:33 pm
I have a Brompton S2L and I am not a fan. I've Bromtonificationised lots of it and it still hasn't clicked. It's fine for short trips but I find the handling lacking over anything more than about 5km. I went 2 speed and titanium to get it as light as possible as I wanted a folding bike I could carry with ease.
I have got involved with the kickstarter www.ridehelix.ca which looks like a very interestingly designed folding bike. I should get mine in May/June and will report back then.
Posted : 27/01/2016 9:40 pm
Which is what they're for.
The whole point of a Brompton is the folding convenience of it all as a part of an integrated transport system. If you want a better folding [b]bike[/b], there are many options out there, but there isn't a better [b]folding[/b] bike, IMHO.
Posted : 27/01/2016 9:46 pm
I agree with CFH - and I actually like the handling - especially with the weight in the bag on the front.
It's genuinely my favourite bike. Mainly for the sens of freedom you get in town when everyone else is stuck. It saved my evening more then once when I was a London commuter. If the trains got stuck half way home - ride! Snow has everyone stuck in the station car park - ride! Late for a meeting a mile away and no cabs/traffic gridlock- ride!
I'd go so far to as as it's one of the best, most useful things I own.
Posted : 27/01/2016 9:58 pm
Never have any probs riding mine 40 or 50 miles. The contact points are all pretty much where they'd be on a 'normal' bike on mine. Sure the weight can be taxing if it's hilly but if it's flatish it takes no more effort to ride than my other bikes.
Posted : 27/01/2016 10:10 pm
I replaced my pedals with wellgo qrd quick release ones. Much better than the originals and you can get flat spd and spdsl versions that just click in place.
Posted : 27/01/2016 10:11 pm
How do people use them if they're not commuting? ie not for on and off trains
Posted : 27/01/2016 10:41 pm
Other than the good advice already posted, I would recommend getting the firm suspension block, couldn't see this mentioned in the previous posts.
Made the same move as the OP 6 months ago, got an S3L in raw. Love it - easily saves 30 mins in waiting for buses/tubes at each end. Swapped the saddle for a charge spoon and the grips for some Ergon GP2s, which give a bit more flexibility in riding position (and make out-of-saddle sprints less sketchy). Stuck Marathons on from new which have been solid so far.
Agree about gearing though - went with standard ratio which never feels quite right. Might look at doing a -12 conversion, the climb up to Queens Park drags.
Posted : 27/01/2016 10:43 pm
Ride to pub
Ride to lunch
Ride to theatre
Ride to friends
Ride to opera
Ride to museum
Ride to dinner
Ride to breakfast
Ride to library
Etc, etc, etc.
Ride places. Take your bike with you. It's ace!
Posted : 27/01/2016 10:46 pm
I'll use mine to ride anywhere if it's raining, my other road bike has mudguards but they don't work quite as well as the Bromptons. Use it to go into town (Liverpool) if I don't have kids with me and I need to go into shops etc. Sometimes if the wife is going somewhere I'll just throw the bike in the boot and ride back, she goes over to Chester to see friends now and then.
Rode back from Manchester along the Canals not long ago, was a great ride, it's what Bromptons are perfect for.
Posted : 27/01/2016 10:48 pm
^ pretty much that. It's also worth it's weight in gold for the occasional times I need to rent a car or van, ride the mile or two there then chuck it in the boot. Never need to bother with a courtesy car for a service either.
Posted : 27/01/2016 10:55 pm
If you are doing it on C2W it takes a bit of fiddling to get the options under the £1000 limit. I don't think you can do rack, 6 gears and Dynamo but 2 of those or stick to default (free) colours.
Worth checking on the Evans site as they occasionally have ex demo with a good discount.
I went for a P6R, if choosing again I'd probably do for the S2 black edition, if you are carrying it, say up a few flights of stairs in your office, the weight does become noticeable.
Posted : 28/01/2016 12:43 am
That ti folder is going to fleeeeeex!
Posted : 28/01/2016 6:17 am
Hmmm, interesting. Would be the thinking mans C2W purchase, given my current bikes. Every now and then I think "if only I had a folder I could lob in the boot"
I like riding my bike, so I do it quite a lot. Local jobs are easier on a proper bike.
My Q wasn't very good. What do people use bromptons for when they're not commuting, and where they work better than a full size bike.
I'm justifying a niche N+1 bike. C2W actual cost is probably close to the used value too
Posted : 28/01/2016 10:53 am
 aP
As CFH said above, I cycle to work on it, its sitting next to me in my office, I cycle to other people's offices on it and take it in with me, I take it to the pub, to the shops, I run errands on it, I sometimes take the long way home on it.
I use it whenever I want to go somewhere wearing ordinary clothing, with a bag on the front, and that I don't want to leave a bike outside.
Posted : 28/01/2016 10:58 am
This. I hate locking up bikes in the street - that combination of theft, vandalism or carelessness (saw a bike on a rack snapped in half by a reversing lorry last week) means it's never worry free. The brompton goes inside nearly anywhere - I've checked it into the cloakroom at the RFH and at michelin starred restaurants. It's quicker to fold and take inside a shop than it is to lock it outside.
To add a bit more extra weight we have http://www.abus.com/uk/Mobile-Security/Bike-Safety-and-Security/Locks/Folding-locks on ours for the rare occasion we do lock it up.
We've got 6 speeds with Son Dynamos and I upgraded to LED lights. the 3x2 gearing is a bit crap - my rear mech never works properly so it gets used as a 3 speed. I'd like a better hub gear when this one fails.
The front bag 'system' is excellent but we've yet to find a bag we're completely happy with. Stuff bounced out of the nylon 'basket', the old design S bag is an odd shape that makes it hard to get much in (narrower at the top than the botttom). The original C bag (?) is OK but basic. My Carradice City M bag is a good size and looks the part but the buckles are an annoying affectation.
I suspect the O bag is the most practical though these look very cool -
http://www.kenfosterscyclelogic.co.uk/m9b0s359p934/BROMPTON-Game-Bag-%28Olive%29-2015
(even if once again they have buckles that value appearance over convenience)
Posted : 28/01/2016 11:21 am
Have you considered a Kansi 3twenty?
The 20" wheels are far more comfortable than the 16" on the Bromptons.
IF you are riding on typical british roads i would wager that the kansi will be a better ride.
The Kansi is currently £330 from most retailers.
Posted : 28/01/2016 3:37 pm
So C2W is about to open, and I have a £1k limit to stick to. Unfortunately it's a Halfords scheme but bikefix is an option and I like them as a shop, they're also close to work
I was going to spec one up as type handlebars:
black
3 speed
Rack and guards
Eazy wheels
Extended post
Marathon tyres
That comes to £980 which is pretty good. I might ask to upgrade to marathon plus, if available
Questions-
1- presumably normal panniers fit onto the rack?
2 -I can get the £15 front mount, but obviously not a bag, is it worth it? i.e. for a later upgrade
3- what is the 'firm suspension' upgrade?
4- still pondering 2 gears over 3, I'm thinking stick to 3 for just in cases, but maybe get an 8% gearing increase?
Posted : 14/03/2016 4:59 pm
1. Nope. The rear rack can only take a top bag, most luggage goes on the front. If you want to carry normal panniers, I make a front rack.
2. Doesn't make any difference to the cost either way, you can buy the front bag and block later. But it would save you having to bolt it on yourself, though that's not hard.
3. Stuffer rubber block in the back, makes it bounce less when pedalling hard.
4. 3 is heavier, but wider range - and can be upgraded easily to 6, whereas upgrading 2 to 6 is more expensive.
Posted : 14/03/2016 5:42 pm
Rear rack is pointless.
Posted : 14/03/2016 5:44 pm
Does make the part-folded bike stand up better. And you can carry other stuff on it 😉
[url= https://farm7.staticflickr.com/6025/5874075749_2122440426_z.jp g" target="_blank">https://farm7.staticflickr.com/6025/5874075749_2122440426_z.jp g"/> [/img][/url][url= https://flic.kr/p/9X5b56 ]Heavily Loaded Brompton[/url] by [url= https://www.flickr.com/photos/cycleologist/ ]Ben Cooper[/url], on Flickr
I make an integral rack on my rear triangles - a slimline one just for the bike to stand on, or beefier ones for large top bags.
Posted : 14/03/2016 5:49 pm
Great, thanks, I didn't realise the rack was that pointless. I'll stick with mudguards only and no rack
I was wondering whether a rack mount child seat might fit (Polisport Guppy with a clamp to sit on most racks), but I reckon the foot rests will be too close to the floor and might touch when cornering. Would be neat to be able to lob the bike and child seat in the bike for impromptu stuff. I know you can get the IT seat, but £210 seems a bonkers amount of cash. I wonder if it'll tow my double trailer!
How much does the extended seatpost stick out? Is it enough to stick on the SQR mount for a Carradice bag
Posted : 14/03/2016 6:58 pm
It sticks out by 6cm - and of course you can just not put the post all the way down when you fold. Though leave too much out and the post won't lock the rear triangle properly.
the rear rack is way too low for a childseat, Milian make an adaptor thingy fir a seat in front of you.
Posted : 14/03/2016 7:02 pm
Brompton gearing is a bit of a minefield if you're new to them. I run a 44t front chainring on my S2, but it's relatively low-geared and not good for long journeys or when you want to get a move on. Google Brompton Alfine conversions; I think they will run an Alfine without any serious modification. That will give you a decent range of gearing.
One immediate upgrade I can recommend, is swapping the very narrow handlebars for something wider. Brompton bars are about 520mm wide; I use a 590mm bar without any issues. You'll need either a flat bar or one with anarrow centre bulge though, otherwise you won't get it though the stem clamp.
Marathon Plus tyres are the most durable, but heavy and stiff. The standard Marathons are a decent compromise and a better performing tyre.
"Rear rack is pointless."
Agreed. You have to take stuff off to fold the bike, which defeats the object.
Posted : 14/03/2016 7:47 pm
Well, I do it with a new rear triangle - but that lets you run a disc brake too. Or I do the Sturmey 8-speed hub, which will fir the standard Brompton rear triangle. Both options are heavier, though, so it depends if you really need that wide a gear range.
Posted : 14/03/2016 10:11 pm
Those narrow bars are ace in traffic, though. It's not a performance vehicle, it's all about practicality!
M3L here, by the way. Of all my bikes, it's the cleverest, most versatile, most smile-inducing of the lot. Love it.
Posted : 14/03/2016 10:17 pm
The current 6-speed Bromptons have 6-speed hub gears, not the 3x2 that they used to have. Anyone know how the weights of the 3 and 6 speed hubs compare?
Posted : 14/03/2016 10:35 pm
They do?
Posted : 15/03/2016 7:50 am
Just had to replace the first part on my Brompton in well over two years.
New rear brake pads....
Still not needed any maintenance whatsoever.
Posted : 15/03/2016 8:11 am
black
Really? They look much better in bright colours.
Extended post
Other option is the telescopic, then replace the top section and Brompton clamp with a cheap seatpost and use a normal saddle. The bike still folds small when it needs to (which might be important for you on some trains as you're using it to commute).
Buy the mount and a front bag - it's far and away the best way to carry luggage on a Brompton.
Posted : 15/03/2016 9:28 am
I'm about to start on an all-black Brompton with Rohloff, Hope discs, SON lighting etc - but with a copper-plated main frame. That's going to be gorgeous.
Brompton with proper luggage:
Posted : 15/03/2016 10:48 am
They do?
Er, no, they don't. 😳 I misread something. Sorry.
Posted : 15/03/2016 11:15 am
PLEASE POST PICS WHEN DONE!!!!
I'm happy with my 3spd SA gears but would love discs on mine!
Nothing about this on the Brompton website...
Posted : 15/03/2016 11:23 am
I went into Bikefix earlier, they also have no idea about the 6 hub gears
Not sure about S or M handlebars, will test ride a couple of options either tomorrow or Wed night
It's not really being used for the commute, I'm 10 miles from my office in Central London so normally use the bike to cycle in. This is an N+1 purchase to try out a folding bike (in summary) - there are various little reasons but they're hard to justify against the cost. Also, I'm short on space but can fit a folder in the garage with a bit of jiggling about so figured I'd try one
I'm not sure about brompton luggage, it's a bit proprietary so I can't use it easily on my other bikes. I think I'm going to avoid it for now and use a normal bag, although I'd be tempted by a front rack if I could find one I like. As it won't get ridden much a bag might be easier to pick up when I know how i'll use the bike
I am thinking about a different colour to black, particularly as I have some spare budget (within the £1k limit) - what's everyones favourite colour? I'm leaning towards bright orange or green
They have an all black brompton they can modify from 2 spd to 3 spd, but they only come with a standard seatpost, the extended one costs more
Posted : 15/03/2016 1:32 pm
And would you have a different frame colour to extremities? I'm thinking lime green for both
Sorry, this couldn't be further from a mountain bike!
Posted : 15/03/2016 1:37 pm
Personally think they look better in a single colour and bright. That said, mine is raw laquer.
Posted : 15/03/2016 1:52 pm
Raw laquer is over budget, I agree that looks mint though
All over lime green it is I reckon
Posted : 15/03/2016 2:15 pm
Claret with Ti extremities. but they don't do it any more 🙁
Posted : 15/03/2016 3:39 pm
 aP
The bag system is the other best bit about bromptons after the folding thing. Click it on, ride to where you want to go, reduced sweaty back etc etc. IMHO the bike handles better with a bag on the front as well, you can carry a surprising amount of weight in them as well.
Posted : 15/03/2016 4:39 pm
aP +1. Part of what makes the bike really useful
Posted : 16/03/2016 8:30 am
Thanks for all your help folks, really helped
I went for a test ride at Bikefix last night. S2L and M3L, extended and telescopic seat posts. M bars definitely worked better for me than S bars, the S was too low (I'm 6'3), and the telescopic seat post gives me the option to leave the seat post slightly extended to get to the right height immediately, as well as potentially leave an SQR mount on
I also popped into the Brompton shop in Covent Garden only to look at the colours
I've just put my order in
M3L, orange all round (didn't like the look of the lime green), marathon tyres, telescopic post, firm suspension, saddle bag/cover
It's just crept over budget, but I get the bike I want. I'll sort out luggage after, I was going to be paying cash anyway so there was no benefit doing it straight away. I can also work out what luggage suits me best
Should be here in 4 weeks or so
Posted : 18/03/2016 10:43 am
benp1 - Member
Sorry to dredge up an old thread but, PICS!!! 😀
Posted : 30/01/2017 3:20 am
Don't have pics I can share quickly, but I have some on strava from the ride I did on Saturday
https://www.strava.com/activities/847158298
Bike was excellent, carried a bag with snacks and bits and my son the whole way without grumbling
Mostly on tarmac/brick/paving stone with the odd gravelly/tracky bit
EDIT - I had a really nice chat with a woman in Woolwich, she stopped while we were taking the photo of the cannon and chatted away about Bromptons and cycling
I've had more chats with random people due to my brompton than any other bike combined
Posted : 30/01/2017 12:01 pm
Unless you are 100% sure why not ride a normal bike to Brighton station and then Boris Bike round London. Much less aggro and expense and you end up spending less time looking loke a ****. Plus trying to manual a Boris bike gives hours of entertainment
Posted : 30/01/2017 12:14 pm
I live in North London and cycle commute in. But if I was coming in from further on the train then I could still see Brompton benefits
- easier to cycle on the same bike (e.g. using the same bike)
- don't have to lock/leave a bike at the station
- don't have to find boris bike stations (I love boris bikes, but they aren't always exactly where you want them)
- the boris bike spots near train stations are hugely popular
- you get the option of going home via other methods - part way cycle? Change station in or out?
Posted : 30/01/2017 12:59 pm
I used a BB from W'loo to Victoria and London Bridge for two years without any problems.
Bloody awesome things.
Posted : 30/01/2017 4:42 pm
